You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will show how to separate the battery from the Palm Treo 650.
  1. Position the phone so the screen faces down.
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. To remove the battery cover, hold down the button in the middle of the phone's back.
    • To remove the battery cover, hold down the button in the middle of the phone's back.
    • Slide the cover down to remove. Set the cover aside.
  3. Lift the edge of the battery, separating contact points, and pull out as pictured. Lift the edge of the battery, separating contact points, and pull out as pictured.
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
cgood
122 Reputation
7 Guides authored
Cal Poly, Team 19-3, Maness Fall 2009 Member of Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 Members
18 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,531
