Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
This guide will walk you through the steps to remove the motherboard on a Palm T|X.
  1. Orient the device so that the display faces forward. Remove the stylus from the right side.
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Turn over the device so that the back panel faces forward.
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Rotate the device so that the display faces forward. Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. LCD iPhone Screen Fix Kits
    The budget option, covered by our Lifetime Warranty.
    Shop Kits
    Cut repair costs, not quality.
    Shop Kits
  5. Carefully pry the back panel to open the device. Be careful not to break the wire that connects the battery pack to the motherboard.
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  6. Use a plastic opening tool to peel the battery pack from the back panel. The battery pack is glued to the back panel so removing it may require considerable effort.
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  7. Use a soldering iron to disconnect the battery wires from the motherboard. For soldering instructions, you can view the Soldering Guide.
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  8. Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them. Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  9. Lift the mother board out of the device. A weak adhesive attaches the motherboard to the device.
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
Spencer Lewson
748 Reputation
6 Guides authored
Cal Poly, Team 1-15, Amido Winter 2011 Member of Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,093
