Introduction
this repair guide will help you to swap the memory of your Packard Bell.
Turn off the laptop completely.
Remove the two Phillips # 000 screws and remove the cover.
Use your fingers to undo the case on the bottom.
To the right of the already installed RAM modules, you will find the brackets that secure the RAM in the bracket. Press the two clips outwards.
The Ram chip folds up slightly after unlocking and can then be easily removed. Repeat this process to remove the second RAM as well.
Insert the new RAM and press it down with a little pressure, so that the memory is back in the holder.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
