This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
After several years of working correctly, the PEAZEFAIR PZEM-061 panel voltmeter broke down overnight, starting to take incorrect measurements: it reads 230 V as 1995V and 99.99A, values that are completely impossible in a home.
View of the display powered at 230 V and view of the housing, with a back cover that is very easy to remove by prying; as soon as it is opened, we can see the main culprit of the failure, the 1 µF yellow capacitor (knowing that this is the one that fails comes from experience gained in other repairs of electronic equipment).
Before replacing the cover: Test the device; when powered at 241 V, it measures exactly the same as it did before the failure. In this home, the utility company voltage is higher than the 230 V standard.
End of the Repair Guide.
A very simple repair; a component failure that is very common in many devices. When you find a flat capacitor, either 1 uF 275V, 2.2 uF, or 3.3 uF, always be suspicious of them, as they are usually the cause of many failures that are simple to resolve.
Follow these instructions in reverse order to reassemble your device.
2 other people completed this guide.
