Introduction
How to fix squeaky water flow
Parts
No parts required.
Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
  • Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
  • Shake it a litlle so the tube can get out here.
  • This clear plastic is fragile,
  • be careful with it or the clipse may break.
More pictures, look.
  • More pictures, look.
  • you can clean it with citric acid.
  • How to open. First remove two PH2 screws left and right.
  • PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted.
  • Now pull it downwards. Now turn around and you see the plastic from the lever.
  • This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
  • Now spray some SILICONE_SPRAY on the moving parts, i made some red circles for it. Just a little bit, also on the springs.
  • TRY, move it, now the noise should gone, whiole moving it.
  • Thats it, reassemble it, be careful with the notches and clipse.
  • done. :)
easy
2 other people completed this guide.
Special thanks to these translators:
100%
Schwarzstein is helping us fix the world! Want to contribute?
Start translating ›
Schwarzstein
2,230 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 16
All Time: 442
