Ozeino OW810 Motherboard Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
14
Past 30 Days:
61
All Time:
437
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
If your Ozeino OW810 gaming headset isn't working and you've already checked that the battery is working, the motherboard may be damaged. The charging port is soldered to the motherboard, so if you suspect the problem is the port, it's necessary to remove the motherboard to desolder and replace the old port.
Before you begin this repair, make sure that the headset is off and unplugged from the charger.
    1. Ozeino OW810 Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Before beginning this guide make sure you have gathered your tools.
      • You will need The Marlin Screw Driver Set
      • It will take approximately 3 min to get assembled
      • Once your tools are gathered you may begin the guide
      Ask FixBot
    2. Ozeino OW810 Motherboard Replacement: step 2, image 1 of 1
      • Before beginning detach the ear muff
      • Use the Metal Spudger to help detach
      • Highlighted in the red circle is what needs to be detached in order to start the guide
      • Everything will be located on the left side of The Ozeino OW810
      Ask FixBot
    3. Ozeino OW810 Motherboard Replacement: step 3, image 1 of 1
      • After detaching the ear muff gather your tools
      • You will need The Marlin Screw Driver set
      • Take The Phillips #0 screwdriver to begin
      Ask FixBot
    4. Ozeino OW810 Motherboard Replacement: step 4, image 1 of 1
      • Highlighted in red is the first screw needed to remove
      • Use Phillips #0 to unscrew
      Ask FixBot
    5. Ozeino OW810 Motherboard Replacement: step 5, image 1 of 1
      • Highlighted is the second screw needed to be removed
      • Use Phillips #0 screwdriver
      Ask FixBot
    6. Ozeino OW810 Motherboard Replacement: step 6, image 1 of 1
      • Highlighted is the third screw needed to be removed
      • Use Phillips #0
      Ask FixBot
    7. Ozeino OW810 Motherboard Replacement: step 7, image 1 of 1
      • Highlighted is the fourth screw needed to be removed
      Ask FixBot
    8. Ozeino OW810 Motherboard Replacement: step 8, image 1 of 1
      • Highlighted is the fifth screw needed to be removed
      Ask FixBot
    9. Ozeino OW810 Motherboard Replacement: step 9, image 1 of 1
      • Highlighted is the last screw needed to be removed
      • You should have unscrewed 6 screws from the ear muff
      Ask FixBot
    10. Ozeino OW810 Motherboard Replacement: step 10, image 1 of 1
      • After unscrewing the screws from the ear muff remove the piece
      • Locate circuit board highlighted
      Ask FixBot
    11. Ozeino OW810 Motherboard Replacement: step 11, image 1 of 2 Ozeino OW810 Motherboard Replacement: step 11, image 2 of 2
      • Highlighted are the screws needed to be removed from the circuit board
      • Remove the motherboard from the headset.
      Ask FixBot
Ashley Martinez
217 Reputation
1 Guide authored
1 Guide Comment
There is a lot of repetition regarding the tools. I recommend being clear in the beginning which tool to use and only repeating when another tool is used. The tools and screws are the main area I would recommend fixing. This is a good guide, and easy to understand.
Morgan G - Reply Share
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 61
All Time: 437
