Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓If your Ozeino OW810 headset is not charging properly, not holding charge, or not working completely follow this guide to replace the headset's battery.
The battery sources the life of the entire headset and microphone. A faulty or dead battery can result in many problems as listed above.
Before using this guide, ensure that you have tried charging the headset for a reasonable amount of time and failed. Try with multiple charging cords and wall outlets to make sure the headset is the issue. Also, check the wiring around and to the battery to ensure all is well and connected.
Multiple steps in this guide require you to remove circuit boards and mess with wiring. Before beginning to ensure that your headset is turned off and completely unconnected from any external power source.
Tools
Spudger4.9
Insert a nylon spudger in the seam between the right ear pad and the driver housing.
Pry the right ear pad off.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
