Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement
  1. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: step 1, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Thermal Cutoff Fuse: step 1, image 2 of 2
    • This is an Oster Digital Electric Kettle
  2. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 1 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 2 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Remove the bottom: step 2, image 3 of 3
    • Remove the three screws. They are tri-wing or triangular slotted screws. My set labeled them as number 4.
    • Once removed the plastic cover comes right off.
  3. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 1 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 2 of 3 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Find the Thermal Cutoff Fuse: step 3, image 3 of 3
    • The Thermal Cutoff Fuse is pressed up against the heat element by a spring clip.
    • Remove the screw, a standard number 2 phillips head.
    • Slide the fiberglass sleeve down and off the fuse
  4. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: step 4, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Test the fuse: step 4, image 2 of 2
    • With ohm meter connected either way the fuse is open. A sure sign that the part is bad.
  5. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: step 5, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Verify the new fuse: step 5, image 2 of 2
    • Testing the new fuse shows that electricity can flow through it.
    • I purchased 5x of SF188E 192 10A/250V SEFUSE on ebay. You can just search for whatever is written on the side of yours.
  6. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: step 6, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Replace the fuse: step 6, image 2 of 2
    • Replace the fuse. The black band is down in this picture.
    • The difficult part is that this part is not soldered in, it is held together with a crimp band.
    • So one must slowly open the band and then crimp it back on the new fuse.
    • I really have no good way of doing this, and it is the most time consuming and frustrating part of the whole repair. Take your time with a pick and pliers and slowly open them and replace the fuse.
  7. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: step 7, image 1 of 2 Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Put all back together: step 7, image 2 of 2
    • Now just slide the fiberglass sleeve back over the fuse.
    • Reattach the spring clip to hold the fuse on the heat element.
    • Make sure that the clip is directly over the fuse before tightening.
    • Replace the plastic cover and install the three tri-wing screws.
  8. Oster Digital Electric Kettle BVST-EK5967 Thermal Cutoff Fuse Replacement, Try it out: step 8, image 1 of 1
    • Plug it back in and see if it heats water.
Scot Henderson
857 Reputation
2 Guides authored
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 75
All Time: 18,033
