Oster BLSTSS-PZO Blades & Seal Ring Replacement
  1. Oster BLSTSS-PZO Blades & Seal Ring Replacement, Blades & Seal Ring: step 1, image 1 of 1
    • First, remove the blender container from the blender base by grabbing the container and lifting it up.
  2. Oster BLSTSS-PZO Blades & Seal Ring Replacement: step 2, image 1 of 1
    • Flip the container, where the bottom faces you.
    • Then, rotate the bottom piece counter-clockwise to remove it from the container.
  3. Oster BLSTSS-PZO Blades & Seal Ring Replacement: step 3, image 1 of 1
    • Carefully remove the bottom piece from the container.
    • Be careful while removing the blades from the container, as seeing they are very sharp and can hurt you.
  4. Oster BLSTSS-PZO Blades & Seal Ring Replacement: step 4, image 1 of 1
    • Now, your container and blades are separated.
Farhan
104 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 462
