Introduction
This guide will show you how to replace the lever springs on your Oster 3905 toaster.
Take off both rubber feet using a small metal spudger.
Wedge a spudger under the feet and pull up to pop off.
Use the plastic opening tool to remove the top metal panel by prying the 4 top metal tabs upwards. They will be able to slide through the openings and be pulled upwards.
Use a metal spudger to pry the 8 tabs upwards along the metal that separates the two slots.
Pull the metal spacer upwards to release from the toaster.
Remove the spring wrapped around a metal rod at the front of the toaster, located behind the white plastic lever holder.
