Oregon Scientific Meep! X2 Battery Replacement
  1. Oregon Scientific Meep! X2 Battery Replacement, Rear Casing: step 1, image 1 of 1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Battery Replacement: step 2, image 1 of 3 Oregon Scientific Meep! X2 Battery Replacement: step 2, image 2 of 3 Oregon Scientific Meep! X2 Battery Replacement: step 2, image 3 of 3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Battery Replacement: step 3, image 1 of 3 Oregon Scientific Meep! X2 Battery Replacement: step 3, image 2 of 3 Oregon Scientific Meep! X2 Battery Replacement: step 3, image 3 of 3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: step 4, image 1 of 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: step 4, image 2 of 3 Oregon Scientific Meep! X2 Battery Replacement, Remove the ribbon cable.: step 4, image 3 of 3
    • Gently unhook the black security clips to loosen the ribbon cable. Use one of the plastic opening tools.
    • Pull lightly on the ribbon cable to remove it.
  5. Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: step 5, image 1 of 2 Oregon Scientific Meep! X2 Battery Replacement, Sever the adhesive glue on the battery.: step 5, image 2 of 2
    • Use your spudger to separate the battery from the adhesive glue strips and plastic film.
  6. Oregon Scientific Meep! X2 Battery Replacement: step 6, image 1 of 2 Oregon Scientific Meep! X2 Battery Replacement: step 6, image 2 of 2
    • Use a soldering station to unsolder the battery wires from the motherboard.
    • In the case of screen or screen sensor replacement, disregard desoldering steps.
J'mel Henneman
864 Reputation
8 Guides authored
USF Tampa, Team 9-1, Blackwell Winter 2015 Member of USF Tampa, Team 9-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G1
3 Members
16 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 1,454
