Opening the Hood
  1. Opening the Hood, Opening the Hood: step 1, image 1 of 2 Opening the Hood, Opening the Hood: step 1, image 2 of 2
    • Locate the hood latch beside the driver's side door, right next to the left foot rest.
  2. Opening the Hood: step 2, image 1 of 1
    • Pull the latch toward you to release the hood.
  3. Opening the Hood: step 3, image 1 of 2 Opening the Hood: step 3, image 2 of 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  4. Opening the Hood: step 4, image 1 of 1
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
  5. Opening the Hood: step 5, image 1 of 1
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • Let the hood rest on the stand.
Shaun MacDonald
2,543 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
22 Guides authored
Past 24 Hours: 47
Past 7 Days: 326
Past 30 Days: 1,476
All Time: 45,599
