Opening procedure
  1. Opening procedure, Unfasten the back cover screws: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Use a Tri-point Y00 driver to unfasten the four screws on the back of the watch.
    • Don’t worry about removing the screws, they will stay in place in the back cover.
  2. Opening procedure, Wedge open the back cover: step 2, image 1 of 2 Opening procedure, Wedge open the back cover: step 2, image 2 of 2
    • Insert an opening tool between the back cover and the metal housing.
    • Twist the opening tool to create a wider gap.
    • Don't fully remove the back cover just yet. The sensor flex cable is still connected to the motherboard.
  3. Opening procedure, Disconnect the sensor flex cable: step 3, image 1 of 3 Opening procedure, Disconnect the sensor flex cable: step 3, image 2 of 3 Opening procedure, Disconnect the sensor flex cable: step 3, image 3 of 3
    • Lay the watch face down.
    • Carefully lift the back cover up from the edge with the buttons to access the sensor connector.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  4. Opening procedure, Remove the back cover: step 4, image 1 of 2 Opening procedure, Remove the back cover: step 4, image 2 of 2
    • Remove the back cover.
    • Make sure the rubber gasket (marked red) is undamaged. If damaged replace it with a new one during reassembly to maintain proper water resistance.
Tobias Isakeit
117,296 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,521 Guides authored
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 60
All Time: 2,255
