Opening the Galaxy Watch
  1. Opening the Galaxy Watch, Opening Procedure: step 1, image 1 of 1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Opening the Galaxy Watch: step 2, image 1 of 2 Opening the Galaxy Watch: step 2, image 2 of 2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Opening the Galaxy Watch: step 3, image 1 of 2 Opening the Galaxy Watch: step 3, image 2 of 2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Opening the Galaxy Watch: step 4, image 1 of 2 Opening the Galaxy Watch: step 4, image 2 of 2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Opening the Galaxy Watch: step 5, image 1 of 3 Opening the Galaxy Watch: step 5, image 2 of 3 Opening the Galaxy Watch: step 5, image 3 of 3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
5 other people completed this guide.
Tobias Isakeit
117,226 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,519 Guides authored
One Comment
I got 3 out of 4 screws out 1 screw just won't come out need help
peck24hi.mp - Reply
Past 24 Hours: 11
Past 7 Days: 48
Past 30 Days: 206
All Time: 10,318
