Open the Quickmill 05000A fully automatic espresso machine
  1. Open the Quickmill 05000A fully automatic espresso machine, Open: step 1, image 1 of 1
    • Never forget to unplug the power cord!
    • Remove the water tank, pulp drawer and bean container.
  2. Open the Quickmill 05000A fully automatic espresso machine: step 2, image 1 of 3 Open the Quickmill 05000A fully automatic espresso machine: step 2, image 2 of 3 Open the Quickmill 05000A fully automatic espresso machine: step 2, image 3 of 3
    • Remove two Phillips screws at the top.
    • Remove four Phillips screws from the back panel. They are very deep and you need a screwdriver with a very long shaft.
    • Remove three Phillips screws from the bottom of the back panel
  3. Open the Quickmill 05000A fully automatic espresso machine: step 3, image 1 of 3 Open the Quickmill 05000A fully automatic espresso machine: step 3, image 2 of 3 Open the Quickmill 05000A fully automatic espresso machine: step 3, image 3 of 3
    • Unscrew the two Phillips screws on both sides of the back.
    • Then pull the back part backwards. Watch out for the power cord.
  4. Open the Quickmill 05000A fully automatic espresso machine: step 4, image 1 of 2 Open the Quickmill 05000A fully automatic espresso machine: step 4, image 2 of 2
    • Open the front door.
    • The front part is still attached with two Phillips screws. turn them out.
  5. Open the Quickmill 05000A fully automatic espresso machine: step 5, image 1 of 1
    • The front part now only hangs with cables on the connection buttons of the control panel. In order to get better access to the brew group or the grinder, it is sufficient to push the front part forward about 10 cm. If that's not enough, you have to free the control panel.
Work the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
171,602 Reputation
219 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 272
