Community-Contributed Guide
Introduction
Go to step 1 ↓For most repairs, the Latissima housing must be opened. These instructions show you how to do this.
Tools
Remove all attachments such as the water tank, milk tank, and capsule drawers.
Turn the device over so that the back is facing you.
Remove the four Phillips screws.
Remove the back cover; it may be a little stuck.
Pull the right side panel back by about 1cm and remove it
The top cover is secured with a Phillips screw under the side panel. Unscrew that screw.
Push the cap behind the lever for the brewing unit back about 1 cm and remove it.
Bend the two tabs on the sides of the connector to the side using a small flat screwdriver.
Use a suitable tool, e.g., small needle-nose pliers. Be extremely careful when pulling the connector toward you. Work slowly and patiently.
Follow the steps in reverse order to reassemble your device
Special thanks to these translators:
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
