Introduction
This guide will detail how to replace the keyboard in the One Education Infinity:One laptop.
Use a spudger to pry the four rubber pads away from the bottom of the case.
Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
Pull the ribbon cable straight out of the ZIF connector.
Use a spudger to lift up the black retaining flap on the touchpad's ZIF connector.
Pull the ribbon cable straight back to remove.
