One Education Infinity:One Back Case Prerequisite
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. One Education Infinity:One Back Case Prerequisite, Back Case: step 1, image 1 of 2 One Education Infinity:One Back Case Prerequisite, Back Case: step 1, image 2 of 2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Back Case Prerequisite: step 2, image 1 of 2 One Education Infinity:One Back Case Prerequisite: step 2, image 2 of 2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Back Case Prerequisite: step 3, image 1 of 1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Back Case Prerequisite: step 4, image 1 of 2 One Education Infinity:One Back Case Prerequisite: step 4, image 2 of 2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
Taylor Bratsch
5,742 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 76
