Onda VI10 Battery Replacement
  1. Onda VI10  Battery Replacement, Battery: step 1, image 1 of 1
    • Use a number 0 screw driver to remove the four screws.
  2. Onda VI10  Battery Replacement: step 2, image 1 of 1
    • Power Button on the side should be pointing outward.
    • Note: This is so the ribbon cables are not damaged.
  3. Onda VI10  Battery Replacement: step 3, image 1 of 1
    • Heat up the back of the device with a hair dryer to loosen the glue.
  4. Onda VI10  Battery Replacement: step 4, image 1 of 1
    • Pry up battery from plastic using a nylon spudger or plastic opening tool.
  5. Onda VI10  Battery Replacement: step 5, image 1 of 1
    • Desolder the two battery cables from the mother board.
Clint Richards
101 Reputation
1 Guide authored
IUPUI, Team S4-G3, Baechle Spring 2017 Member of IUPUI, Team S4-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G3
4 Members
6 Guides authored
One Comment
Hi ! Thx for the tuto !
Were can i shop thé battery ?! Please ? I live in France...
mauriciano67 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 655
