Remove the 4 screws on the inner face of the camera.
Circuit ribbon is attached at the top left of the camera. Be careful when separating the front and back of the camera.
Pull the camera apart into 2 separate pieces.
You should be left with 4 large pieces, the outer case, inner lens piece, outer silver band and back case containing the LCD display.
Pull up on the small ribbon wire to disconnect it from the circuit board
Flip the little black clip up to remove the larger ribbon wire from the circuit board.
