Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
You will need a clean, well-lit area, an iFixit repair kit including the specialized screw driver, along with the Phillips #000 bit. We also recommend you have an organization tray in order to keep track of all the screws you will be taking out.
  1. Remove nine 4.45mm Phillips #000 screws from the outside of the case. Remove nine 4.45mm Phillips #000 screws from the outside of the case.
    • Remove nine 4.45mm Phillips #000 screws from the outside of the case.
  2. There are four screws to take out on the bottom of the camera.
    • There are four screws to take out on the bottom of the camera.
  3. There are three screws to take out on this side.
    • There are three screws to take out on this side.
  4. There is one screw to take out on this side.
    • There is one screw to take out on this side.
  5. There is one hidden screw inside the HDMI port.
    • There is one hidden screw inside the HDMI port.
  6. Using the blue plastic opening tool, wedge open and remove the case.
    • Using the blue plastic opening tool, wedge open and remove the case.
  7. Once you have the back case off, remove the LCD Screen.
    • Once you have the back case off, remove the LCD Screen.
  8. Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Using a plastic opening tool, gently lift the retaining flap on the display cable ZIF connector.
    • Pull the display cable from its socket on the motherboard.
  9. Remove the LCD screen from the device.
    • Remove the LCD screen from the device.
    • Be careful not to rip the display's ribbon cable as you pull the screen away from the device.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 285
