Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
You might want to tell them that the little yellow ribbon has a little thing you have to lift to remove the ribbon from the mother board. I thought I killed it. The rest of your instructions are perfect. Thanks
Using a plastic opening tool, gently pry the display to get the lifting started.
Due to adhesive, lifting the remainder out with your hands will be necessary. Lift until the display has separated from the frame.
6 other people completed this guide.
One Comment
this site doesn't sell the Nook Color display. Where did you get yours?
