Orient the phone as shown.
Press the button with the plastic opening tool and slide the back case downward relative to the phone.
Insert the plastic opening tool into the marked space.
Lift up the side of the battery closest to the bottom edge of the phone using the plastic opening tool.
Insert the plastic opening tool in the marked areas in between the front and back covers.
Pry each corner with the plastic opening tool until the front case completely detaches.
Lift the bottom edge of the front panel at a 45 degree angle.
Remove front panel by slowly pulling it away from the phone at a 45 degree angle.
Locate the speaker location located on the back panel of the phone.
Using the tweezers place one side of tweezers in the rectangular slot where the speaker is located
Slowly lift speaker away from the back panel.
