Nokia Lumia 900 Front Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
89
All Time:
923
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Nokia Lumia 900 Front Camera Replacement, Opening The Phone: step 1, image 1 of 2 Nokia Lumia 900 Front Camera Replacement, Opening The Phone: step 1, image 2 of 2
      • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
      • Using the opening tool, pry the screen from the casing until they are separated from each other.
      Ask FixBot
    1. Nokia Lumia 900 Front Camera Replacement, Detach Ribbon: step 2, image 1 of 1
      • Detach camera ribbon from motherboard
      Ask FixBot
    2. Nokia Lumia 900 Front Camera Replacement, Remove Camera: step 3, image 1 of 1
      • Peel camera off of adhesive surface
      • Use caution when removing camera as it is fragile
      Ask FixBot
    3. Nokia Lumia 900 Front Camera Replacement, Installing New Camera: step 4, image 1 of 1
      • Apply adhesive to back of camera
      • Attach ribbon to motherboard
      • Press down on camera for 60 seconds
      • Let dry for 5 minutes
      Ask FixBot
    4. Nokia Lumia 900 Front Camera Replacement, Reassembling Screen: step 5, image 1 of 1
      • Slide the hinges of the left side of the screen under the left side of the plastic case
      • Clamp the right side of the screen down and make sure screen is flat
      • The screen should "click" into place
      Ask FixBot
Joshua Crosman
304 Reputation
5 Guides authored
1 Guide Comment
Is also forgot to tell about the plate between screen and battery that is glued to the battery
John Bork - Reply Share
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 89
All Time: 923
