Nokia Lumia 900 Battery Replacement
    1. Nokia Lumia 900 Battery Replacement, Opening The Phone: step 1, image 1 of 2 Nokia Lumia 900 Battery Replacement, Opening The Phone: step 1, image 2 of 2
      • Remove the Sim card tray and locking bar, before applying pressure to to the top right corner of the plastic casing.
      • Using the opening tool, pry the screen from the casing until they are separated from each other.
      Ask FixBot
    1. Nokia Lumia 900 Battery Replacement, Remove Old Battery: step 2, image 1 of 1
      • Detach connector A from the phone.
      • Use the opening tool to pry out battery from the phone.
      • The battery should come out fairly easily
      Ask FixBot
    2. Nokia Lumia 900 Battery Replacement, Installing New Battery: step 3, image 1 of 1
      • Place the battery in the empty battery slot
      • Attach connector A to the battery terminal.
      Ask FixBot
    3. Nokia Lumia 900 Battery Replacement, Reassembling The Screen: step 4, image 1 of 1
      • Slide the hinges of the left side of the screen under the left side of the plastic case
      • Clamp the right side of the screen down and make sure screen is flat
      • The screen should "click" into place
      Ask FixBot
Finish Line
2 other people completed this guide.
Joshua Crosman
304 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 103
All Time: 3,363
