Nokia Lumia 620 LCD Display, Touch screen Glass
Video Overview
  1. Nokia Lumia 620 LCD Display, Touch screen Glass, Switch Off: step 1, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass, Switch Off: step 1, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass, Switch Off: step 1, image 3 of 3
    • Switch off the phone, remove the battery and SIM (Memory) card.
    • The lower back cover is held by 3x T4 Torx screws.
    • The screws are of two types!
  2. Nokia Lumia 620 LCD Display, Touch screen Glass, Lower Back Cover: step 2, image 1 of 2 Nokia Lumia 620 LCD Display, Touch screen Glass, Lower Back Cover: step 2, image 2 of 2
    • Loudspeaker
    • Touch screen flex cable connector
    • LCD Display flex cable connector
  3. Nokia Lumia 620 LCD Display, Touch screen Glass, Touch screen Test: step 3, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass, Touch screen Test: step 3, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass, Touch screen Test: step 3, image 3 of 3
    • If you want to replace the Digitizer, let's test the spare part first.
    • Be careful, don't break the flex cable.
  4. Nokia Lumia 620 LCD Display, Touch screen Glass: step 4, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 4, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 4, image 3 of 3
    • Another three screws hold the Upper Back Cover.
    • Disconnect the Touch screen and the Digitizer flex cables.
  5. Nokia Lumia 620 LCD Display, Touch screen Glass: step 5, image 1 of 2 Nokia Lumia 620 LCD Display, Touch screen Glass: step 5, image 2 of 2
    • If you have not yet disconnected the Digitizer and the Touch screen flex cables, do it now.
    • The Logic Board is held to the Middle frame by two plastic clips.
  6. Nokia Lumia 620 LCD Display, Touch screen Glass: step 6, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 6, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 6, image 3 of 3
    • With a plastic tool gently release the mother board and remove it.
  7. Nokia Lumia 620 LCD Display, Touch screen Glass: step 7, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 7, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 7, image 3 of 3
    • Front Camera and Proximity & Light sensor module
    • Earpiece
    • Remove them one by one.
  8. Nokia Lumia 620 LCD Display, Touch screen Glass: step 8, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 8, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 8, image 3 of 3
    • The Midle frame is held by 6x locking clips, three on each side. Release them and remove the Middle frame.
  9. Nokia Lumia 620 LCD Display, Touch screen Glass: step 9, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 9, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 9, image 3 of 3
    • Now gently remove the LCD Display.
    • If you have a broken LCD, replace it and reassemble the phone.
    • We will continue with removing the Touch screen Glass.
  10. Nokia Lumia 620 LCD Display, Touch screen Glass: step 10, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 10, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 10, image 3 of 3
    • Put a scotch tape to prevent the glass from scattering.
    • With a hot air warm the glass to soften the adhesive.
    • You can use a hair dryer for this operation.
    • Start with separating at the middle, where the bonded area is smaller.
  11. Nokia Lumia 620 LCD Display, Touch screen Glass: step 11, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 11, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 11, image 3 of 3
    • Continue with the separation by using a plastic tool.
  12. Nokia Lumia 620 LCD Display, Touch screen Glass: step 12, image 1 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 12, image 2 of 3 Nokia Lumia 620 LCD Display, Touch screen Glass: step 12, image 3 of 3
    • Clean the remnants of the old adhesive tape.
    • If the spare parts come without adhesive tape, you must put by himself.
    • Prepare the new digitizer glass and install it.
    • Reassemble the device.
  13. Nokia Lumia 620 LCD Display, Touch screen Glass: step 13, image 1 of 1
    • That's all.
    • Did you do it successfully?
13 other people completed this guide.
ZFix
191,278 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,532 Guides authored
2 Comments
great guide! I made it quite easily, thanks so much
tave - Reply
i am purchase urgent
priyamotors - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 9,941
