Introduction
This guide is to instruct the reader how to disassemble the Nokia 6310i so that they can access the screen.
Press and hold the battery release button and slide the battery away from the Nokia logo
Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Remove the screen from the motherboard by carefully pushing the four tabs around the edge.
Carefully pull the screen away from the motherboard.
