Introduction
This guide is to instruct the reader about the steps on replacing the internal antenna. The phone will have to be disassembled to reach to the antenna. A proper set of Torx (Star) screw-driver is necessary to complete the procedures.
Press and hold the battery release button and slide the battery away from the Nokia logo
Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
