Nokia 6030 Front Cover Replacement
  1. Nokia 6030 Front Cover Replacement, Battery: step 1, image 1 of 3 Nokia 6030 Front Cover Replacement, Battery: step 1, image 2 of 3 Nokia 6030 Front Cover Replacement, Battery: step 1, image 3 of 3
    • Press down on the grip on the back of the phone and slide the rear housing down towards the bottom of the phone.
  2. Nokia 6030 Front Cover Replacement: step 2, image 1 of 3 Nokia 6030 Front Cover Replacement: step 2, image 2 of 3 Nokia 6030 Front Cover Replacement: step 2, image 3 of 3
    • Use your finger to gently pull the bottom of the battery up by using the slip found at the bottom of the phone.
    • Lift out battery and remove.
  3. Nokia 6030 Front Cover Replacement, SIM Card: step 3, image 1 of 3 Nokia 6030 Front Cover Replacement, SIM Card: step 3, image 2 of 3 Nokia 6030 Front Cover Replacement, SIM Card: step 3, image 3 of 3
    • Use your finger to lift the metal cage up.
    • Remove SIM card.
  4. Nokia 6030 Front Cover Replacement: step 4, image 1 of 1
    • Use your finger to close the metal cage.
  5. Nokia 6030 Front Cover Replacement, Front Cover: step 5, image 1 of 3 Nokia 6030 Front Cover Replacement, Front Cover: step 5, image 2 of 3 Nokia 6030 Front Cover Replacement, Front Cover: step 5, image 3 of 3
    • Pull the top casing up after inserting thumbs under the two tabs labeled with the arrows. then slowly rotate up and over the screen.
  6. Nokia 6030 Front Cover Replacement: step 6, image 1 of 2 Nokia 6030 Front Cover Replacement: step 6, image 2 of 2
    • After removing the top cover, turn the phone over so the screen is facing upwards.
  7. Nokia 6030 Front Cover Replacement: step 7, image 1 of 3 Nokia 6030 Front Cover Replacement: step 7, image 2 of 3 Nokia 6030 Front Cover Replacement: step 7, image 3 of 3
    • Lift the front off the phone by pulling above the arrows.
Spencer Woodworth
316 Reputation
9 Guides authored
Cal Poly, Team 23-63, Johann Spring 2010 Member of Cal Poly, Team 23-63, Johann Spring 2010
CPSU-JOHANN-S10S23G63
3 Members
17 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 3,062
