Nintendo Wii U GamePad Analog Stick Replacement
  1. Nintendo Wii U GamePad Analog Stick Replacement, Battery: step 1, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement, Battery: step 1, image 2 of 2
    • Face the GamePad down and unscrew the two Phillips #00 screws which are attached to the battery cover.
    • Lift up and remove the battery cover.
  2. Nintendo Wii U GamePad Analog Stick Replacement: step 2, image 1 of 3 Nintendo Wii U GamePad Analog Stick Replacement: step 2, image 2 of 3 Nintendo Wii U GamePad Analog Stick Replacement: step 2, image 3 of 3
    • With your finger on the battery connector, pull downwards toward the base of the GamePad to disconnect it.
    • Pull upwards from the bottom of the battery to release it.
  3. Nintendo Wii U GamePad Analog Stick Replacement, Outer Case: step 3, image 1 of 3 Nintendo Wii U GamePad Analog Stick Replacement, Outer Case: step 3, image 2 of 3 Nintendo Wii U GamePad Analog Stick Replacement, Outer Case: step 3, image 3 of 3
    • Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  4. Nintendo Wii U GamePad Analog Stick Replacement: step 4, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement: step 4, image 2 of 2
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back plate.
  5. Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: step 5, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement, Analog Stick: step 5, image 2 of 2
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  6. Nintendo Wii U GamePad Analog Stick Replacement: step 6, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement: step 6, image 2 of 2
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  7. Nintendo Wii U GamePad Analog Stick Replacement: step 7, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement: step 7, image 2 of 2
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  8. Nintendo Wii U GamePad Analog Stick Replacement: step 8, image 1 of 1
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  9. Nintendo Wii U GamePad Analog Stick Replacement: step 9, image 1 of 2 Nintendo Wii U GamePad Analog Stick Replacement: step 9, image 2 of 2
    • Remove the two 9.0mm Tri-wing Y0 screws.
    • Lift out the analog stick.
85 other people completed this guide.
Kim Arre
4,918 Reputation
8 Guides authored
Cal Poly, Team 17-20, Forte Winter 2013 Member of Cal Poly, Team 17-20, Forte Winter 2013
CPSU-FORTE-W13S17G20
5 Members
38 Guides authored
35 Comments
where can i find replacement analogs for wiiu gamepad and wiiu procontoller?
Victor Torres - Reply
www.ebay.com
mhuntersr -
They are available at ebay.com Cost around 7,50 $ Left & Right (different - look what you need). Comes all from china or hong Kong but Quality is 1A (so far i can tell).
Frederik Rischmann -
Bump previous question because dogs seem to enjoy their texture.
maskedpainter - Reply
Has anyone tried this?
http://dx.com/p/replacement-3d-analog-st...
I know it says for the pro controller. But based from the images, the pins could be compatible.
wandererwk - Reply
Past 24 Hours: 23
Past 7 Days: 164
Past 30 Days: 720
All Time: 99,897
