Introduction
A prerequisite for removing the upper LCD.
Using a pair of tweezers, pull the microphone out of its housing in the front bezel.
De-route the microphone cable, and pull it through the right hinge.
Using the flat end of a spudger, pry the left speaker out of its socket on the front bezel.
De-route the speaker cable along the top edge of the screen.
In the same manner described above, remove the right speaker from its socket on the front bezel.
Place both speakers on the back of the upper LCD.
Remove the seven 2.5 mm silver screws securing the power board to the upper case.
Lift the power board up off the upper case.
Push the D-pad up through its housing in the upper case. Remove the D-pad.
In the same way, remove the power button from the upper case.
Using a pair of tweezers, remove the LED diffuser bracket and the LED diffuser from the upper case of the DSi XL.
Place the tip of a spudger in the LED diffuser compartment, on the face of the clutch hinge.
Push the clutch hinge to the left.
Lift the left side of the front bezel away from the upper case.
Pull the front bezel to the left, separating the front bezel from the upper case.
Grasp the camera and upper LCD ribbon cables between your thumb and forefinger, pulling them out of the upper case slightly, slide them down through the slit in the upper case.
Rotate the front bezel assembly clockwise so that the ends of the camera and LCD cables slide sideways through the slit in the front bezel.
Carefully coil the two ribbon cables together, so that the connectors are on the inside of the spool.
Holding the upper LCD and the cameras together, pull the cables through the hinge in the front bezel.
Uncoil the ribbon cables.
