Nintendo 3DS XL Battery Replacement
  1. Nintendo 3DS XL Battery Replacement, Battery: step 1, image 1 of 2 Nintendo 3DS XL Battery Replacement, Battery: step 1, image 2 of 2
    • Loosen the two 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Battery Replacement: step 2, image 1 of 2 Nintendo 3DS XL Battery Replacement: step 2, image 2 of 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set aside.
  3. Nintendo 3DS XL Battery Replacement: step 3, image 1 of 3 Nintendo 3DS XL Battery Replacement: step 3, image 2 of 3 Nintendo 3DS XL Battery Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
Charlene Donlon
10,215 Reputation
8 Guides authored
Cal Poly, Team 9-13, Regan Spring 2014 Member of Cal Poly, Team 9-13, Regan Spring 2014
CPSU-REGAN-S14S9G13
5 Members
43 Guides authored
Past 24 Hours: 28
Past 7 Days: 186
Past 30 Days: 941
All Time: 48,475
