Nintendo 3DS XL 2015 Circle Pad Replacement
  1. Nintendo 3DS XL 2015 Circle Pad Replacement, Circle Pad: step 1, image 1 of 1
    • Ensure device is turned off and the stylus and game card are removed.
  2. Nintendo 3DS XL 2015 Circle Pad Replacement: step 2, image 1 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 2, image 2 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 2, image 3 of 3
    • Turn the device so that the back cover is facing you and locate the two screws at the top of the back cover.
    • Using the Phillips #000 screwdriver, loosen the screws on the back cover.
    • The screws do not come out, but may be loosened to allow for the back cover to be removed.
    • Gently pry the tabs on the side of the device with the metal spudger or your thumbnail and lift off the back cover.
  3. Nintendo 3DS XL 2015 Circle Pad Replacement: step 3, image 1 of 2 Nintendo 3DS XL 2015 Circle Pad Replacement: step 3, image 2 of 2
    • Remove the microSD card by pushing it in, the card should automatically pop out.
  4. Nintendo 3DS XL 2015 Circle Pad Replacement: step 4, image 1 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 4, image 2 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 4, image 3 of 3
    • To remove the battery, hold the device with the battery facing up in one hand, with a finger securely gripping the lid of the device, and gently flip the device over to your other hand. The battery should fall into your hand.
  5. Nintendo 3DS XL 2015 Circle Pad Replacement: step 5, image 1 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 5, image 2 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 5, image 3 of 3
    • Remove the two rubber bumpers on the back of the device with a thumb tack.
    • Using the Phillips #00 screwdriver, remove all 8 of the screws holding the bottom cover to the motherboard.
    • Lift off the bottom cover, being sure not to disconnect the two ZIF connectors for the L/R buttons on the back of the device.
  6. Nintendo 3DS XL 2015 Circle Pad Replacement: step 6, image 1 of 2 Nintendo 3DS XL 2015 Circle Pad Replacement: step 6, image 2 of 2
    • Using the Phillips #00 screwdriver, remove the two screws holding the circle pad in place.
    • Be sure to keep these screws separate from the bottom cover screws, the circle pad screws are slightly longer and only compatible with the circle pad.
    • Lift the circle pad out of its place to expose the ZIF connector.
  7. Nintendo 3DS XL 2015 Circle Pad Replacement: step 7, image 1 of 1
    • Using the tip of the spudger, gently lift off the lid of the ZIF connector to release the circle pad cable.
  8. Nintendo 3DS XL 2015 Circle Pad Replacement: step 8, image 1 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 8, image 2 of 3 Nintendo 3DS XL 2015 Circle Pad Replacement: step 8, image 3 of 3
    • Take the new circle pad assembly and insert the cable back into the open ZIF connector and close it using the spudger.
    • Ensure the internal component of the circle pad is correctly oriented with a small screwdriver or spudger.
    • Gently place the new circle pad back into its place and secure with the screws.
    • We had to try this step a few times before we were able to orient it correctly. Try to make sure that the circle pad does not move the internal assembly once it is inserted.
Past 24 Hours: 35
Past 7 Days: 232
Past 30 Days: 984
All Time: 27,549
