Introduction
Replace the stylus housing in your Nintendo 3DS and give your metal stylus a comfortable place to sleep.
Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
Pull the back cover up and away from the rest of the device to remove it.
Insert a plastic opening tool into the notch in the lower case above the battery.
Pry the battery up with the plastic opening tool.
Grab the top edge of the battery and lift it out of the lower case.
Remove the nine 6.3 mm black Phillips screws from the lower case.
Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
Lift the bottom edge of the lower case off the rest of the 3DS.
Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
Remove the lower case from the device.
Remove the four 2.4 mm Phillips screws that secure the stylus housing to the lower case.
Use a plastic opening tool to pry the stylus housing up from the lower case.
Grab the stylus housing and remove it from the lower case.
