Introduction
If your C-Stick doesn't work, you may need to replace it. Watch out for delicate ribbon cables in the device. After removing the board with the C-Stick attached, the face buttons can fall out. Make sure to not lose them.
Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
Reorient the device so that the game slot now faces you.
Remove the two rubber bumpers along the top of the device using tweezers.
Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
Remove the four 3mm Phillips #00 screws.
Remove the three 3mm Phillips #00 screws.
2 other people completed this guide.
3 Comments
What do I do if two of my screws were stripped when I got my system? I need to fix my cstick desperately but I cant get inside of my 3ds. Anything at all would help.
~Akiru
Hello Akiru! Stripped screws can be a bugger, but you do have some options. I could outline some of your options here, but iFixit has a good article for this one. Go ahead and take a look at the article on iFixit titled "How to Remove a Stripped Screw", it should help you out.
Have a Good One.
Tyler
you do have the option of just ripping it out
