Nikon D90 Replacing the SB / IF card
  1. Nikon D90 Replacing the SB / IF card, Remove the bottom cover: step 1, image 1 of 1
    • Remove the three screw in red
    • Remove the three long screw in orange
    • Remove the screw in yellow
    • Use a little of WD40 if the screw is blocked
  2. Nikon D90 Replacing the SB / IF card, Remove the back cover: step 2, image 1 of 3 Nikon D90 Replacing the SB / IF card, Remove the back cover: step 2, image 2 of 3 Nikon D90 Replacing the SB / IF card, Remove the back cover: step 2, image 3 of 3
    • Remove the 4 screw in green
    • Remove the 2 screw in yellow
  3. Nikon D90 Replacing the SB / IF card: step 3, image 1 of 3 Nikon D90 Replacing the SB / IF card: step 3, image 2 of 3 Nikon D90 Replacing the SB / IF card: step 3, image 3 of 3
    • Slacken the grip side of the cover first
    • Remove the cover wholly.
    • Be carefull with the two flex cables
  4. Nikon D90 Replacing the SB / IF card: step 4, image 1 of 3 Nikon D90 Replacing the SB / IF card: step 4, image 2 of 3 Nikon D90 Replacing the SB / IF card: step 4, image 3 of 3
    • Disconnect the FPC of the back cover
    • Toggle up the black plate to free the flex cable
    • Remove the grip cover by rotating
  5. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: step 5, image 1 of 3 Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: step 5, image 2 of 3 Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 1/3: step 5, image 3 of 3
    • Toggle up the black plate and disconnect the flex cable
    • Toggle up the white plate and disconnect the flex cable
    • Push up the right slide of the connector to free it
  6. Nikon D90 Replacing the SB / IF card, Disconnect all the cables - part 2/3: step 6, image 1 of 1
    • Push up the bottom of the connector to free it
  7. Nikon D90 Replacing the SB / IF card, Detach the protection plate: step 7, image 1 of 3 Nikon D90 Replacing the SB / IF card, Detach the protection plate: step 7, image 2 of 3 Nikon D90 Replacing the SB / IF card, Detach the protection plate: step 7, image 3 of 3
    • Remove the six screws to free the protection plate
    • Disconnect the white cables
    • Disconnect the microphone Cable
  8. Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: step 8, image 1 of 3 Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: step 8, image 2 of 3 Nikon D90 Replacing the SB / IF card, Disconnect all cables - Part 3/3: step 8, image 3 of 3
    • Disconnect the speaker cable
    • Remove the two screws to free the PCB
    • Toggle th PCB from Left to Right
  9. Nikon D90 Replacing the SB / IF card, Disconnect the cable on the bottom of the PCB: step 9, image 1 of 1
    • Disconnect the black cables
  10. Nikon D90 Replacing the SB / IF card, Free the IF/SB PCB: step 10, image 1 of 2 Nikon D90 Replacing the SB / IF card, Free the IF/SB PCB: step 10, image 2 of 2
    • Push the IF/SB PCB
    • Unsolder the 3 Wires ( Red, Black, Orange )
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
JOLY
182 Reputation
1 Guide authored
Nexurium - Bastien JOLY Member of Nexurium - Bastien JOLY
Business
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 2,190
