Use a spudger to lift the black tab on the ZIF connector.
Disconnect the ribbon cables from their respective ZIF connectors on the logic board.
Peel back the yellow tape covering the cable connector on the back of the casing you removed.
18 other people completed this guide.
4 Comments
Be extra careful removing / installing those ribbon flex cables. I think I damaged mine, so the screen and the buttons on the back cover no longer work and I may need to buy new parts. In order to disconnect the cables from ZIF connectors in Step 9, the tiny black bar (flap) on the connector needs to be pushed towards the camera bottom, and the cables will come off by themselves. When installing the cables back, make sure the black bar is up, align the cables against the connector and close the black bar back, locking the cables.
