Nikon D90 Flash Bulb Replacement
  1. Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 1 of 3 Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 2 of 3 Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 3 of 3
    • Use a plastic opening tool to lift up the flash.
  2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: step 2, image 1 of 2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: step 2, image 2 of 2
    • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
    • Be careful not to strip the screw heads.
  3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 1 of 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 2 of 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 3 of 3
    • Use a plastic opening tool and carefully pry open the top casing of the flash.
    • Then, lift off the top casing of the flash.
  4. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: step 4, image 1 of 2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: step 4, image 2 of 2
    • Carefully unclip the bulb casing from the plastic casing using tweezers.
    • Remove the black and white tape on the bulb casing.
    • This tape is what holds the wires and bulb in place.
  5. Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 1 of 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 2 of 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 3 of 3
    • Remove the rubber stopper on the left and right side of the bulb.
    • Separate the rubber stopper from the white and black tape.
    • The bulb can now be slid out and replaced.
    • Be careful not to break the bulb or cut yourself on the broken bulb.
8 other people completed this guide.
jonothon cawley
354 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
6 Guides authored
2 Comments
thanks for instruction…………really helpfull
hebi - Reply
Hi guys do you know where to get this bulb?please help
Martin Mitter - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 7,019
