Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
Remove the 3 screws under the battery flap and remove the bottom cover.
There is an addition screw at the very top of the battery bay. If you don't remove this screw, you will damage the core body of the camera (Ask me how I know).
Yes. There is another screw inside the battery bay. You save a lot of D7100 👍
Tu -
Remove the 2 screws on each side of the view finder.
Only 1 screw on each side of viewfinder totaling 2 screws, 1 on the left and 1 on the right.
Remove the 2 screws above and below the SD card flap.
the two screws under the car door turn very hard (D7200). I affixed a 25mm plastic (delrin) wheel on my JIS 00 + screwdriver for better torque. This worked.
Step 7 might be skipped, if you just need to get at the LCD screen. This side panel with the car slits only supports the lower screw for the back panel in step 8. The back panel might lift off in step 10, without removing the side panel of step 7. If step 10 does not lift off, do step 7 preceding step 10.
This step has 4 screws total. 2 above and 2 below. You throw off the screw count if you don't label each step correctly. Not a mistake but a bit of a play on words making a quick glance seem deceptive.
Remove the Diopter adjustment control sticker and remove the screw under it.
If you skipped step 7, you have to loosen the 4 step 7 screws by about 1mm to get the back panel off cleanly in the next step.
Disconnect the LCD ribbon cables and power cable from the motherboard.
Flip up the dark grey tab on the ribbon cable connector with your fingernail to release the clamp before removal. When reassembling ensure the cable is fully reinserted then push the tab back down to lock.
Unscrew all 16 screws around the back plate of the camera.
This does not need to be done whatsoever for mode dial replacement. This is only needed if you are replacing the screen.
Then unscrew the remaining screws holding the back plate to the LCD.
Then simply remove the plate with the LCD.
When starting disassembly group each set of removed screws from each disassembly section and GROUP them, put an earbud cleaner or similar inbetween each group of screws to seperate them as you progress through the disassembly. Then you can work back in reverse when you have installed the new LCD screen. Remember to use a dust blower to remove flakes of the old LCD after installing the new LCD before starting to put the screws back.
I used about 15 ziplocked bags to hold each step screws parts in. Having hard time removing's LCD glass from frame .
11 other people completed this guide.
9 Comments
I DID IT! A couple notes: 1) You don’t need to disconnect the ribbon cables from the body. I’m new to fine electronics repair like this and I didn’t want to mess around with more cables than necessary. 2) My body doesn’t have a plastic cover over the LCD (probably why it broke…) and as such I had to reallllly pry it off. 3) Learn how to reconnect ribbon cables - I had no idea.
A couple of points. This is listed as a LCD display replacement. Says only said to buy tools… Need the LCD screen as well. No idea of cost or a link to buy same. Also, you do not show removing the screen and remounting. I appreciate all the instructions on screws, but do not feel this was complete. Thanks for your instructions to this point.
That’s very easy guide to understand. I hope to see a full guide for the Nikon D7200. thank you http://www.nikonbundle.com/nikon-d7200-b...
My replacement screen cost about £44 gbp pounds from China on Ebay. The main ribbon cable is released by flipping up the thin dark grey strip opposite the ribbon using a finger nail or plastic tool on the socket then you just gently pull the cable out, the thin cable is wee bit different, using a small screw driver or dentist tool just unclip and pull/push it down towards the thin ribbon cable then slide ribbon out. When all done clean the screen on the camera and fit a thin glass protector from JJC on ebay to give more protection.
(D7200) My replacement screen cost about £44 gbp pounds from China on Ebay. The main ribbon cable is released by flipping up the thin dark grey strip opposite the ribbon using a finger nail or plastic tool on the socket then you just gently pull the cable out, the thin cable is wee bit different, using a small screw driver or dentist tool just unclip and pull/push it down towards the thin ribbon cable then slide ribbon out. When all done clean the screen on the camera and fit a thin glass protector from JJC on ebay to give more protection.
When disassembling, put the tiny screws into little groups with a separator., this will make it easier to reverse build, The power cable on the D7200 is only two ribbons - one thin one and a wide ribbon.
When removing the old screen it will be glued to the frame, use a dentists pick tool to carefully prise it out, then scrape any old left over glass out if any.
Many thanks for a good clear guide! The only problem I had was reconnecting the ribbon cables. After a bit of research I found that you need to flip up the dark grey tabs on the ribbon cable connectors with your fingernail to release the clamps before removing the cables. When reassembling ensure the cables are fully reinserted then push the tabs back down to lock.
what type glue holds the new screen in place.
Muy buena explicación yo tengo una Nikon d7500 y se quebró la pantalla espero que pronto puedan subir el mismo procedimiento para la d7500 muchas gracias por toda la información!
