Introduction
Your camera's motherboard, the main system circuit board which processes inputs and produces outputs, is essential to system operation. This guide will teach you how to access and remove the D5100's motherboard.
Use your fingernail to gently peel back the black rubber thumb grip, attached to the chassis with a strong adhesive.
Use the Phillips #00 to remove the screw underneath the black rubber grip.
Carefully peel back the black rubber hand grip, which is attached to the chassis with a strong adhesive.
Use the Phillips #00 to remove two screws beneath the handgrip.
Warning: these two screws are made from a different material than most of the other ones. They're quite fragile and prone to the screw head wearing out. You don't want that to happen! Make sure you use a good quality screwdriver and apply enough pressure so that your screwdriver doesn't "slide" and damage the screw head.
Using a spudger, pry off the diopter adjustment dial cover and remove the screw underneath.
Next, using a Phillips #00 screwdriver, remove the three Phillips screws around the viewfinder.
Remove the silver 16-pin cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
At this point, the rear panel is fully separated from the main body of the camera.
Use a Phillips #00 screwdriver to remove the five screws holding the motherboard cover plate. Starting with the right side, lift the plate and remove it from the camera body. Set the plate aside.
Located on top of the motherboard, there are six dark orange ribbon cables. Flip the black plastic lock at each cable up to unlock the cable. Pull the cables straight back away from the white connector to release it.
Flip the motherboard out of the camera's body, toward the bottom of the device, to expose its underside.
Using a spudger, peel back the adhesive, that is protecting the large ribbon cable on the underside of the motherboard.
Disconnect the ribbon cable by flipping its clasp up and removing it from the plastic casing in the direction of the cable.
13 other people completed this guide.
4 Comments
Thanks for the guide. I would not have attempted this without your help.
After replacing the main board, the only issue I am having is that the top focus point is not lighting up when I select it. It still works as a focus point, but is not light in the view finder as red. I probably did not perfectly seat one of the ribbon cables. It would be nice if someone new which cable controlled lighting in red the focus dots in the viewfinder.
Thanks so much!
Hey David, where did you get the new mainboard from? Know of any website that sells them? I need one for D5000. Thanks!
pbmbuss -
ebay seller from chicago area has tons of nikon parts
rongyuanxie |
Feedback Score Of
128606 | 99.2%
(i'm not that seller)
