Nikon Coolpix S220 Battery and Memory Card Replacement
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: step 1, image 1 of 1
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: step 2, image 1 of 1
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: step 3, image 1 of 1
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
2 other people completed this guide.
Shauna
798 Reputation
5 Guides authored
Cal Poly, Team 12-32, Maness Spring 2011 Member of Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
4 Members
10 Guides authored
One Comment
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 36
All Time: 19,129
