Fix Your Stuff
Right to Repair
Store
Introduction
This guide will walk you through the necessary steps to access the battery in the Nikon Coolpix E5700.
  1. Use your finger tip to slide the battery release tab toward the battery symbol on the E5700. Open the battery door.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Pull the battery out of the E5700.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
Raana
78 Reputation
2 Guides authored
Cal Poly, Team 24-58, Amido Spring 2011 Member of Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Members
18 Guides authored
One Comment
Seems too easy to be designated "moderate".
andrew - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,334
