Introduction
Replace your worn out inner dome daughterboard: which contains Atmel ATMEGA328P, NXP Semiconductors 44501 Near-Field Communications Controller, TXC 8.00 MHz Crystal Quartz Oscillator, YF04E, and the status LED.
Disconnect the taoglas Wi-Fi Dual Band Antenna by prying with a spudger.
Once the antenna is disconnected, simply pull it off the outside of the inner dome.
Use a T6 Torx screwdriver to undo the three 0.8 mm screws holding the inner dome daughterboard in place.
