Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement
  1. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement, Rear Camra&Front Camera&Headphone Jack: step 1, image 1 of 2 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement, Rear Camra&Front Camera&Headphone Jack: step 1, image 2 of 2
    • Remove SIM card tray.
  2. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 2, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 2, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 2, image 3 of 3
    • Heat up back glass panel.
    • Use hobby knife to open a gap and cut the fierce sticker underneath rear glass panel.
    • The back glass panel is easily shattered and the adhesive underneath is fierce. So be careful to pry this part.
    Be careful around the camera. I managed to melt my camera lens getting pieces of a shattered glass panel off.
    Roger - Reply
  3. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 3, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 3, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 3, image 3 of 3
    • Heat up bottom plastic panel.
    • Use hobby knife to open a gap and insert guitar picks to cut adhesive underneath.
  4. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 4, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 4, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 4, image 3 of 3
    Tool used on this step:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Buy
    • Twist off 6 Phillips screws together.
    • Insert guitar picks and plastic opening tool to separate front assembly from back cover.
    • Attention: These two parts fit tightly.It is very difficult to separate them. You can also try using heavy-duty suction cup to disassemble them.
    I was able to successfully use a suction cup towards the bottom of the device (near the USB-C plug) to get it open.
    Roger - Reply
  5. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 5, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 5, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 5, image 3 of 3
    • Unscrew one Phillips screw.
    • Remove metal bracket securing flex contactors.
    • Release 3 flex contactors and remove it .
  6. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 6, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 6, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 6, image 3 of 3
    • Twist off 5 Phillips screws together and release battery contactor.
    • Remove metal bracket securing LCD contactor.
    • Release metal bracket securing front camera contactor and headphone jack contactor.
  7. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 7, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 7, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 7, image 3 of 3
    • Disconnect signal cable contactor.
    • Release LCD contactor.
    • Pry up and remove motherboard.
  8. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 8, image 1 of 2 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 8, image 2 of 2
    • Remove headphone jack and front camera.
  9. Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 9, image 1 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 9, image 2 of 3 Nexus 6P Rear Camra&Front Camera&Headphone Jack Replacement: step 9, image 3 of 3
    • Release rear camera contactor, then remove it.
10 other people completed this guide.
Witrigs
69,454 Reputation
378 Guides authored
4 Comments
Does the headphone jack have a part number?
I can't find the replacement part anywhere online.
Luke Redfern - Reply
Headphone jack part number 9-HU-2909
I am searching all over the www for headphone jack. It's listed at two stores for $9.99. But, no stock.
Headphone jacks for every other silly phone are available all over the internet for couple of $.
http://www.repairsuniverse.com/huawei-ne...
isaac_kmgm -
Awesome guide! I used this guide to replace my rear camera because the old camera’s focus was stuck in one position (which is a common problem with 6p’s apparently). The guide was spot on, and it has good pictures showing you what to do. It only took me about 30-40 minutes to complete.
Jacob Higgins - Reply
Very useful, even multiple years later. I used it to complete a full mainboard swap as I corrupted the partitions on my original board. I followed this guide and it worked perfectly. Patience is key for the glass camera lens.
Chaney Goldstein - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 5,805
