New Nintendo 3DS XL 2015 Motherboard Replacement
  1. New Nintendo 3DS XL 2015 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. New Nintendo 3DS XL 2015 Motherboard Replacement: step 2, image 1 of 1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. New Nintendo 3DS XL 2015 Motherboard Replacement: step 3, image 1 of 1
    • Once the screws are loosened, pry open the back cover.
  4. New Nintendo 3DS XL 2015 Motherboard Replacement: step 4, image 1 of 1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    • Remove the SD card by pressing it in with your thumbnail until it clicks and partially ejects, then pull it out.
  5. New Nintendo 3DS XL 2015 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Using a JIS #00 screwdriver, remove the six 6mm screws around the edges of the secondary cover.
  6. New Nintendo 3DS XL 2015 Motherboard Replacement: step 6, image 1 of 2 New Nintendo 3DS XL 2015 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, carefully pop out the rubber bumpers located at the top side of the 3DS. Removing them will reveal another two 6mm screws. Remove these screws using a JIS #000 as well.
  7. New Nintendo 3DS XL 2015 Motherboard Replacement: step 7, image 1 of 3 New Nintendo 3DS XL 2015 Motherboard Replacement: step 7, image 2 of 3 New Nintendo 3DS XL 2015 Motherboard Replacement: step 7, image 3 of 3
    • To separate the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
    • Don't fully remove the cover yet, or you may damage the delicate ribbon cable that still connects it to the motherboard.
  8. New Nintendo 3DS XL 2015 Motherboard Replacement: step 8, image 1 of 1
    • Use a pair of tweezers to lift away the two plugs that latch the L/R/ZL/ZR button ribbons to the motherboard. You can now remove the back cover completely and set it aside.
  9. New Nintendo 3DS XL 2015 Motherboard Replacement: step 9, image 1 of 1
    • Use tweezers to flip up the small, hinged locking flap in order to unlock the ZIF connector securing the Circle Pad ribbon.
    • The cable folds over itself and enters the ZIF connector from the left side, but the connector's locking flap flips up from the right side. A common error here is to try pulling up on the same side as the cable is on, when that could break the connector.
    • Slide the ribbon out of the ZIF connector.
    • It may be easier to unscrew and remove the Circle Pad first, then try disconnecting the cable. Similarly, when reinstalling the Circle Pad, you can reconnect the cable first and then put the unit back into place.
  10. New Nintendo 3DS XL 2015 Motherboard Replacement: step 10, image 1 of 1
    • Using a JIS #000 screwdriver, remove the two 8 mm screws securing the circle pad.
  11. New Nintendo 3DS XL 2015 Motherboard Replacement: step 11, image 1 of 1
    • Lift the circle pad casing upward to remove it. There will be some friction, but it should not require excessive force.
  12. New Nintendo 3DS XL 2015 Motherboard Replacement: step 12, image 1 of 1
    • Locate the gold terminal plug with a red cable at the top left of the motherboard. Using your fingers, carefully pull the plug straight upward to remove.
    • Use a pair of tweezers to disconnect the single ribbon connector.
    • Don't do what we did -- be very careful not to pull on the red cable.
  13. New Nintendo 3DS XL 2015 Motherboard Replacement: step 13, image 1 of 3 New Nintendo 3DS XL 2015 Motherboard Replacement: step 13, image 2 of 3 New Nintendo 3DS XL 2015 Motherboard Replacement: step 13, image 3 of 3
    • Using tweezers, gently pull the four marked ribbons out of the ZIF connectors along the sides of the motherboard.
    • These ZIF connectors are held in place by friction and do *not* have locks—lifting the flaps on these connectors will break them! Be careful disconnecting the upper red connector (some people report that it has a clamp while others do not). Double check if your model has a clamp, and when you disconnect the ribbon cable, be excessively gentle.
    • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
    • This one ribbon connector may also have a plastic clamping flap, but it's not like the others, rather it's similar to the one used for the Circle Pad. Gently flip up the flap on the side opposite the ribbon cable to remove the cable.
    • This connector was previously listed among the ones that do not have locks, however on most if not all systems, it actually does have one. Trying to remove or reinsert this cable without unlocking it will damage the cable, requiring a replacement of the Touch Screen's digitizer. Fortunately, the LCD uses other ZIF connectors, so that should still be fine.
    • If, on your system, this connector does not have a lock after all, do not pull up on the flap! It should come up easily; if it doesn't, it probably isn't meant to lock, but instead just hold the cable in with friction. In that case, try gently pulling the cable out of the connector.
    • When reassembling the device, be sure to flip the ZIF clamps back down.
    • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
  14. New Nintendo 3DS XL 2015 Motherboard Replacement: step 14, image 1 of 1
    • Using a JIS #000 screwdriver, remove six 4mm screws along the edges of the motherboard.
  15. New Nintendo 3DS XL 2015 Motherboard Replacement: step 15, image 1 of 2 New Nintendo 3DS XL 2015 Motherboard Replacement: step 15, image 2 of 2
    • Carefully pivot the motherboard 90 degrees toward the hinges to reveal two more ZIF connectors on the underside of the motherboard.
    • Both have latches that must be flipped up. The left, longer latch is black; the right, shorter one is white. Flip up the flaps, slide the ribbons out and remove the motherboard.
    • Note which way the ribbons slide into their connectors carefully, as they are different - specifically the longer screen ribbon cable, which needs the pins facing down/the black plastic part facing up for the top screen to function.
54 other people completed this guide.
BabblingFishes
1,597 Reputation
1 Guide authored
Cal Poly, Team 24-4, Lancaster Spring 2015 Member of Cal Poly, Team 24-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G4
4 Members
32 Guides authored
13 Guide Comments
Could someone point out where the fuses in the motherboard are hidden?
emaN - Reply Share
With some digging, I managed to find this on the GBAtemp forums , which host a community of 3DS modders:
https://gbatemp.net/threads/screwed-up-p...
Seems like no one's quite sure, but it could be a start. Unfortunately, the N3DS components are largely small black boxes with no labeling.
If you have a multimeter, it might help to test some of these mystery boxes.
BabblingFishes - Share
Question: Seeing as how you pulled the red cable in the photos, how was that fixed? Asking for a friend.
Mijii - Reply Share
We...never fixed that actually, as we didn't have the tools for it and the device had been loaned to us specifically for tearing down.
I don't know if iFixit themselves ever did anything with it, but I would imagine soldering the frayed end of the cable back onto the plug would work. (Here's a guide on that: http://www.instructables.com/id/Solderin... )
what version is this on?
isaa sy - Reply Share
Past 24 Hours: 31
Past 7 Days: 229
Past 30 Days: 1,006
All Time: 79,198
