New Nintendo 3DS XL 2015 Battery Replacement
  1. New Nintendo 3DS XL 2015 Battery Replacement, Battery: step 1, image 1 of 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. New Nintendo 3DS XL 2015 Battery Replacement: step 2, image 1 of 1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. New Nintendo 3DS XL 2015 Battery Replacement: step 3, image 1 of 1
    • Once the screws are loosened, pry open the back cover.
  4. New Nintendo 3DS XL 2015 Battery Replacement: step 4, image 1 of 1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
    • Remove the SD card by pressing it in with your thumbnail until it clicks and partially ejects, then pull it out.
To reassemble your device, follow these instructions in reverse order. You might need to set the time after installing the new battery.
40 other people completed this guide.
Kobbe Farwick
2,678 Reputation
2 Guides authored
Cal Poly, Team 24-4, Lancaster Spring 2015 Member of Cal Poly, Team 24-4, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G4
4 Members
32 Guides authored
5 Guide Comments
Bonjour,
Tout d’abord merci pour ces explications claires et précises. Toutefois, je me demandais s’il y avait un endroit où l’on peut trouver une batterie officielle Nintendo ? Après quelque recherches je n’ai malheureusement rien trouvé (et comme la console est vieillissante…)?
Nicolas BARET - Reply Share
Bonjour Nicolas Si vous voulez une pièce de nintendo, vous devez être en amérique ou au canada car nintendo ne vend des pièces que dans ces pays, je peux vous donner le site Web pour les états-unis et le canada si vous le souhaitez.
Nelson Berrios - Share
The battery didn't work at all. After replacing the old battery I plugged it in and the charging light would go off after a few seconds. I tried to turn on the 3ds with the new battery in and all that would happen is the blue light would flash for less than a second and the 3ds wouldn't turn on
Youjustjealous - Reply Share
I too just replaced my battery and had this issue. However, I noticed that when I applied some to heavy pressure on the end of the battery (the end closest to the hinge) it would work. So I just added 2 folded paper sheets (so 4 layers) between the battery and the outer shell. That applied enough pressure for me to use my new battery
Fabian - Share
Past 24 Hours: 42
Past 7 Days: 313
Past 30 Days: 1,109
All Time: 33,694
