Introduction
This guide will show you how to replace a faulty laser.
Looking from above, remove the two 11mm screws with a torx T10 screwdriver.
Lift gently upon the top panel.
Unplug the clip located on the right side before completely removing.
Gently pull back on the gold laser to remove it from the socket.
Unplug the mini LCU clip by gently pulling up and remove the laser.
Where did you buy a new gold laser?
This is my question too!
4 other people completed this guide.
9 Comments
lol. You don’t need to open it to replace the laser. The top is a clip on. Just pull it and remove 4 screws.
where do you buy the replacement laser?
I too would like to know where he got a replacement laser.
where do I buy a replacement laser?
bjurgensen79@gmail.com
Beverly Jurgensen
Where do I buy a replacement laser?
Beverly Jurgensen
I found some replacement lasers:
How many do you have to buy? Is it just one?
I replaced the laser and its still not working. Any other ideas?
pull the free bottom corners out a bit to free the catches
wilfried - Reply
