Nanit Pro N301 Speaker Replacement
  1. Nanit Pro N301 Speaker Replacement, Speaker: step 1, image 1 of 1
    • Insert an opening pick into the seam between the front and rear case.
    • Slide the opening pick around the perimeter of the camera until all of the retaining clips are released.
    • Separate the front and rear case.
  2. Nanit Pro N301 Speaker Replacement: step 2, image 1 of 1
    • Remove the four 4 mm T6 Torx screws from each corner of the circuit board.
    • Lift the circuit board out of the chassis.
  3. Nanit Pro N301 Speaker Replacement: step 3, image 1 of 1
    • Remove the two screws that secure the speaker with a T3 Torx screwdriver.
  4. Nanit Pro N301 Speaker Replacement: step 4, image 1 of 2 Nanit Pro N301 Speaker Replacement: step 4, image 2 of 2
    • Use tweezers to disconnect the speaker motherboard connection.
    • Do not pull on the wires.
    • Remove the speaker.
2 other people completed this guide.
Morgan Hamby
169 Reputation
1 Guide authored
IUPUI, Team 3-1, Harley Spring 2024 Member of IUPUI, Team 3-1, Harley Spring 2024
IUPUI-HARLEY-S24S3G1
3 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 238
