Nabi 2 Battery Replacement
  1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 1 of 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 2 of 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: step 1, image 3 of 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Battery Replacement: step 2, image 1 of 2 Nabi 2 Battery Replacement: step 2, image 2 of 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Battery Replacement: step 3, image 1 of 3 Nabi 2 Battery Replacement: step 3, image 2 of 3 Nabi 2 Battery Replacement: step 3, image 3 of 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Battery Replacement, Battery: step 4, image 1 of 3 Nabi 2 Battery Replacement, Battery: step 4, image 2 of 3 Nabi 2 Battery Replacement, Battery: step 4, image 3 of 3
    • Use the spudger to pop the battery out of place and set it aside.
  5. Nabi 2 Battery Replacement: step 5, image 1 of 3 Nabi 2 Battery Replacement: step 5, image 2 of 3 Nabi 2 Battery Replacement: step 5, image 3 of 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
4 other people completed this guide.
Michelle
851 Reputation
4 Guides authored
USF Tampa, Team 4-3, Lacy Spring 2016 Member of USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Members
14 Guides authored
3 Comments
Was hoping you could provide the replacement part number for this battery.
ellenanders5 - Reply
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
Antanas Stankus - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 9,522
