Introduction
Replacing the NERF Doomlands 2169 Lawbringer Blaster spring is a moderately simple task taking fifteen to thirty minutes to complete. There are no special skills required for this repair. The main spring is responsible for pushing the plunger forward when firing and storing the plunger in a backward position when the gun is primed. The main spring may need to be replaced if the user finds the toy is losing its performance.
Remove sixteen screws from the outer case.
Remove the outer case from the rest of the device.
Almost done!
Finish Line
